Hello,
I'm new here and kindly asking for an opinion about the next situation. I have a Honda translap xl700 from 2008 and i am very happy about it.
Long story Short, a guy mounted a givi engine guard on it and a noticed after a few days that the metal regtagular bar were the givi is connected to the frame ( upper side front part of the frame above the plastic shield) has deformed / flatten a bit around 3 or 4 mm around the tiny givi plate applied with pressure on the frame. Do you think that's because the bars/ metal plate were screw to tight on the frame? I am concerned about the integrity of the frame. I have weaken the screws and I'm thinking I if there is something that I should do about it.
Thank you for your understanding,
Laurentiu
P.s a could upload a few photos for a better idea about the situation.
